ā2006-01-04 10:00 PM
ā2006-01-04 10:06 PM
ā2006-01-04 10:07 PM
ā2006-01-04 10:09 PM
Ian wrote:Ian, if you read his problem you would realize that he said "ONLY" that one connection has a problem. Your solution is global and would affect ALL walls.
Try hitting (F7 on a win machine - clean wall/beam intersection mode on/off)
I just turned mine 'off' and it did what your describing.
Thats the first place i would start.
ā2006-01-04 10:10 PM
Zobi wrote:
In addition to my inability to spell, I perhaps post too quickly. In typing my question, I deriverd a potential solution, and lo, and behold, it worked. My hope now is that someone will see this and be able to learn from it! Hope I'm not cluttering y'alls lives unnecessarily...here's the answer...
the three pink dots indicates an offset for positioning the wall. One had no offset, the other, a 1-1/4" offset. Why they couldn't heal up, still dunno, but changing one so that both had the same offset set it up to work immediately.
thanks for your patience...!
ā2006-01-04 10:13 PM
Zobi wrote:That's sursprising, since usually the reference lines just need to hit each other, not be the same!Zobi wrote:
ā2006-01-04 10:17 PM
ā2006-01-05 07:10 AM
ā2006-01-05 09:06 PM
