fatihb
My floor plan appears in 3d view, but not on the plan.
When I try to draw a wall it redirects to this link
2 Replies 2
Hello fatihb,
All is written. You must consider each elements are visible on their minimum installation levels. You are able to modify it by a right clic on your 3D elements in 2D or in 3D.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
Patrick M
set walls to "symbolic cut" on "home story only", or verify that the floor plan cut plane is counting the story you are on as a "relevant story" by cut and story visibility
