2022-01-18 01:22 PM
My floor plan appears in 3d view, but not on the plan.
When I try to draw a wall it redirects to this link
2022-01-18 02:27 PM - edited 2022-01-18 02:29 PM
Hello fatihb,
All is written. You must consider each elements are visible on their minimum installation levels. You are able to modify it by a right clic on your 3D elements in 2D or in 3D.
2022-01-18 10:16 PM
set walls to "symbolic cut" on "home story only", or verify that the floor plan cut plane is counting the story you are on as a "relevant story" by cut and story visibility
