2016-07-2906:13 AM - last edited on 2023-05-2408:38 AM by Rubia Torres
I have some walls that are 90mm thick and some that are 43mm thick. When I added zones to the floor plan - the zone tool picks up the 90mm thick walls, but not the 43mm ones?
Just tried to use the cadimage bracing tool and same thing. only picks up the 90mm walls. Is there a setting somewhere that I'm not aware of?
Would save me a lot of time if it would recognize the 43mm walls!
Thanks for drawing my attention to the zone boundarys in the walls settings. I wasn't aware that was there. All the walls I had drawn had the right zone setting - but upon a closer look some of the walls weren't quite exactly meeting up with other walls ( had to zoom in a lot)so after I fixed this - the zones were working fine.
As for the Cadimage bracing - A box popped up to tell me that no internal walls had been selected - so by changing the composite name to have 'int' at the front of it solved this problem.
Thought Id just write on here just incase anyone else had the same problem
