Navigator window auto-close feature – gone in AC11?
In prior releases, the Navigator window used to auto-close once the view you select opens (assuming you had the 'stick pin' toggled to the auto close position).
There is no longer a stick-pin icon. Is that feature gone now? Do you have to manually close the Navigator window every single time?
11 REPLIES 11
__archiben
it's still there, but there is no longer a stick pin - just right-click on the top of the navigator and choose 'Auto-Hide Navigator'
~/archiben
b e n f r o s t
Link
Still a pin in PC mode.
Link.
__archiben
ok ok! there is a pin, but it's no longer a button with icon . . .
~/archiben
b e n f r o s t
Link
That's interesting. Does your navigator autohide? Mine doesn't.
The Organizer autohides, but then it's pin is a button, like always.
Wonder if it's a bug?
Link.
__archiben
both navigator and organiser work the same way - as in the screenshot above. they both have the auto-hide function in the context menu, and both auto-hide when asked to. you've got a PC bug i'd say . . .
b
b e n f r o s t
Eduardo Rolon
MIne doesn't…
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Link
I'm not sure if I had noticed this before, but autohide only works with the navigator when it is not docked. But it works docked or undocked for the Organizer.
This is on PC and since there's no docking on a Mac, that's why we experience different results.
I better tell my local reseller about this!
Link.
__archiben
ejrolon wrote:
MIne doesn't…
doesn't have the pin? or doesn't autohide?
if it works docked or undocked for the organiser, i would still say that it's a bug with the navigator.
macs don't have 'docking' but they do 'snap' - to edges and each other. my navigator and organiser both auto-hide if i want them to whether snapped or floating . . .
who's your local reseller mate?!
b
b e n f r o s t
Eduardo Rolon
Does have the pin and I managed to close it but I have no idea how or what did it.
AC27 US/INT -> AC08
another Moderator
