2022-08-23 07:05 PM - last edited on 2022-09-20 04:58 PM by Oleksandra Vakariuk
This is something I haven't seen before - SEO with upwards extrusion , looks fine in 3D, does not look fine in 2D.
Any neat little box I haven't ticked??
Any suggestions?
.Kameliye
2022-08-23 08:54 PM
Solid element operations have never been visible in 2D. This is a long-term wishlist item.
2022-08-23 10:17 PM - edited 2022-08-23 10:20 PM
You can replace wall with a shell and create holes where you can place the openings using a wall. Shell's SEO are reflected in 2d when you set it at floor plan view. Or a curtain wall.....
2022-08-24 12:11 AM
@Kamelite Have you considered using the polygon mode in the wall tool?
2022-08-24 08:21 AM
Aha, I didn't know that.
Good to know! Thank you.
.Kamelite
2022-08-24 08:23 AM
Maybe I should do just that! The matter of the fact is, that I have no prior experience with the polygon mode. This would be a great opportunity to get just that!
Thank you!
.Kamelite
2022-08-24 08:32 AM
Polygon wall worked like a charm!!
Thank you!
.Kamelite
