Never befor seen issues with SEO
Kamelite
This is something I haven't seen before - SEO with upwards extrusion , looks fine in 3D, does not look fine in 2D.
Any neat little box I haven't ticked??
Any suggestions?
.Kameliye
Windows 10, Archicad 28
6 REPLIES 6
Solid element operations have never been visible in 2D.  This is a long-term wishlist item.
AC 29 USA and earlier   •   hardware key   •   macOS Sequoia 15.7.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Botonis
Mentor
You can replace wall with a shell and create holes where you can place the openings using a wall. Shell's SEO are reflected in 2d when you set it at floor plan view. Or a curtain wall.....
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
DGSketcher
Legend
@Kamelite Have you considered using the polygon mode in the wall tool?
Aha, I didn't know that.
Good to know! Thank you.
.Kamelite
Maybe I should do just that! The matter of the fact is, that I have no prior experience with the polygon mode. This would be a great opportunity to get just that!
Thank you!
.Kamelite
Polygon wall worked like a charm!!
Thank you!
.Kamelite
