2025-06-17 12:06 AM
		2025-06-17
		01:38 AM
		2025-06-21
		11:38 AM
Hi Eric,
Those are just new textures from their product with 4 blocs to demonstrate
When you import them into ArchiCAD, you won't be able to use them really but you'll get new materials
To import :
File > External Content > Place Hotlink
Click again on place Hotlink and you'll get to browse to the RVT file
 To import
Files > External Content > Place Hotlink...
Place Hotlink
Browse to your file
It should import like this
Once inside ArchiCAD, you simply have to import the texture folder (each images) that's with it and make the texture you want. You might need to play with the Ambient slider too, to get a good result (or try to find equivalent options in ArchiCAD from the pdf guide in the file)
2025-06-17 11:12 PM
I basically got a new material but not a panel that has no texture or ribs What am I missing
		2025-06-18
		01:58 PM
		2025-06-21
		11:39 AM
I don't think that the panels are that important.
But when you import the RVT file, ArchiCAD should ask you to place them on your floor plan by default
You can find them in your embedded library as objects
Embedded Library > Link > Materials-Wall-MeltSpan... > Walls Form 1.gsm
2025-06-18 03:50 PM
Right now I am lost and some of the dialogs ae too low to read and translate into English.
I do have a new file with the 4 objects. After that nothing works for me.
2025-06-18 10:30 PM
Hey Eric,
Sorry about that, I didn't realize the quality I was uploading.
I edited the first answer above with clearer (I hope) instructions
