Eric Milberger
New Wall Type from RVT files
This file and many others comes from a vendor for corrugated wall panels
Can anyone understand how to use this in Archicad?
Operating system used: Windows 28
Eric Milberger, Architect | Master Planner
5 Replies 5
B_Migito
Hi Eric,
Those are just new textures from their product with 4 blocs to demonstrate
When you import them into ArchiCAD, you won't be able to use them really but you'll get new materials
To import :
File > External Content > Place Hotlink
Click again on place Hotlink and you'll get to browse to the RVT file
 To importTo import
Files > External Content > Place Hotlink...Files > External Content > Place Hotlink...
Place HotlinkPlace Hotlink
Browse to your fileBrowse to your file
It should import like thisIt should import like this
Once inside ArchiCAD, you simply have to import the texture folder (each images) that's with it and make the texture you want. You might need to play with the Ambient slider too, to get a good result (or try to find equivalent options in ArchiCAD from the pdf guide in the file)
Eric Milberger
I basically got a new material but not a panel that has no texture or ribs  What am I missing
B_Migito
I don't think that the panels are that important.
But when you import the RVT file, ArchiCAD should ask you to place them on your floor plan by default
You can find them in your embedded library as objects
Embedded Library > Link > Materials-Wall-MeltSpan... > Walls Form 1.gsm
Eric Milberger
Right now I am lost and some of the  dialogs ae too low to read and translate into English.
I do have a new file with the 4 objects.  After that nothing works for me.
B_Migito
Hey Eric,
Sorry about that, I didn't realize the quality I was uploading.
I edited the first answer above with clearer (I hope) instructions
