New user - couple of questions
Hola. I just started to use ArchiCAD and i have couple of problems. Hope that someone can help me.
>Where can I change to remove these (i guess construction) lines when I export images?
These red lines on doors and windows, green on roof, etc.
>How to set turning on the lights inside house? Recently I stubmled upon lamp tool, but i can't find it now. This should be in library, but no luck with finding it. I know how to set dark outside.
>Where can i switch backgrounds? Like here these clouds. Or something else.
> And can someone redirect me to free library databases, i would like to have more stuff.
And how can I add them into program?
Thanks.
3 REPLIES 3
David Maudlin
Make sure you are using the Lamp Tool, not the Object Tool for the lamps. You can look at Work Environment > Tool Schemes > Tool Box to see where it is on the Toolbox.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
squall_tmo
Hello Lemonzoo,
1) If you just want to remove the contours from the OpenGL view, go to View > 3D view mode > 3D styles; here in the contour sub-menu you can deactivate them (and save your new 3D style for the following times);
2) In the ToolBox (the palette were you can find walls, windows, fills and so on) there are 3 sub-menus: Design, Documents and More; in the last one you can find the "Lamp" tool; if you can't find it there, you can add that tool by changing the Work Environment like David explained before!
3) To change the background go to Document > Creative Imaging > Photorendering Settings; here you can change the sky settings or use a background for the rendering (Set cinerender Environment to None and the set up Background sub-menu the way you prefer);
if you want to use the same background in the openGL view too, you just need to open the 3D Styles window again and in the Background sub-Menu you can find the "As in Photorendering" Checkbox;
4) About 3D objects, you can find some websites here: http://www.graphisoft.com/downloads/parametric_objects.html
otherwise, if you just need 3D shapes, with a Projected plan view only, you can also download ARCHICAD goodies, because there is a plug-in to open 3ds file format, that is hugely more easy to find on the web. Obviously there are Pros and Cons in importing 3ds files, but you have a some choices.
Thanks for help, guys. I'll try your advices.
