‎2003-12-15
10:43 AM
‎2023-05-23
03:45 PM
Rubia Torres
‎2003-12-16 09:31 AM
‎2003-12-16 09:35 AM
David wrote:Very good! Are the egdes of the "hole" by the walls vertical?
Here's an ArchiForma solution, just for fun. The soffit can be easily modeled using the "ruled surface" tool, basically giving you a truncated pyramid, and then rotated into position under a normal roof slab.
If you plan to do this sort of thing a lot a parametric scripted GDL object using RULED might be another way to go.
‎2003-12-16 09:37 AM
David wrote:Please excuse my ignorance...Is this part of the ArchiForma package or is it part of AC8.0 ?
....If you plan to do this sort of thing a lot a parametric scripted GDL object using RULED might be another way to go.
‎2003-12-16 10:04 AM
"Michael Craig" wrote:
Please excuse my ignorance...Is this part of the ArchiForma package or is it part of AC8.0 ?/quote]
RULED is a GDL command, that you can use in your scripting - which is a little too much for you at this point in time, I suppose.
To try ArchiForma, check http://www.cigraph-store.com.
To Try GDL Toolbox, check http://www.gdltoolbox.com.
‎2003-12-16 10:09 AM
‎2003-12-16 10:19 AM
‎2003-12-16 10:24 AM
Very good! Are the egdes of the "hole" by the walls vertical?Actually,
Congrats for 5000th message!What!? No mug!?
‎2003-12-16 10:25 AM
‎2003-12-16 10:28 AM
