Newbie question
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2013-11-22
01:12 AM
‎2023-05-24
09:06 AM
Rubia Torres
‎2013-11-22
01:12 AM
Thx,
Marc
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-11-22 03:16 AM
‎2013-11-22
03:16 AM
Welcome Marc.
Try hitting the C key to change your construction method and see if that gets you going in the right direction (see what I did there?).
You can also adjust the Reference Line Location in your info box, to do the same thing.
Link.
Link.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-11-22 04:02 AM
‎2013-11-22
04:02 AM
Thx for your reply. So I tried this and the result is the same. See attached pic. I drew this from left to right, then hitting "C" in between each wall section. What I need is the brick to be on the other side of the wall.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-11-22 08:18 AM
‎2013-11-22
08:18 AM
In AC17, using C will change the position of the Reference Line, using P shortcut will flip the Wall - this flip is also available with a single button in the info box and Wall Too Settings next to the reference line locations.
You should also indicate which version and setup you are using in your signature
James Badcock
Graphisoft Senior Product Manager
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-11-22 01:12 PM
‎2013-11-22
01:12 PM
Awesome. Thx James and I have updated my signature 😉
