James B
No Depth Mesh not showing up in Zero Depth Section
I'm using AC8.1 so that could be the reason for this.
But I'm taking a zero depth section through my model. And it seems meshes with no depth are not appearing.
Have people realised this? Or is it just me? Any solutions?
Solutions which aren't appropriate are limited depth (as the section staggers) or adding depth to the mesh (as the mesh is being a roof element).
Has this been solved in AC9?
Thanks in advance
James Badcock
13 Replies 13
Dwight
Too bad about your misbehaving rooster.
Dwight Atkinson
James B
yeah, thanks Dwight!
As they say, you can't choose your family.
James Badcock
Djordje
Peter wrote:
It's not just you. I just tested it and a section with zero depth does not show the mesh.
VERSION, ladies and gentlemen, VERSION!!!!
If anything does not show in zero depth S/E, make it one mm (or whatever crazy fraction those imperialists across the pond use) deep - shallow? - and it will.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
James B
I couldn't do this. As the section I use is a staggered section, and the limited section distance does not do stagered as well.
I should just upgrade to AC9
James Badcock
