No Line between Walls with different Fills
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2012-12-14
04:29 AM
2023-05-24
12:51 PM
Rubia Torres
I am curious what people think about this situation:
Do you guys think this is a bug or is this supposed to work like this? Or is there a case why this is OK to work like this?
I have two Walls, one is the continuation of the other, but has a different Fill. Their Reference Lines are in the same line and join. There should be a Line where they join.
I think it is a bug.
Workaround: switch the Reference Line of one of the Walls to the other side.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-14 08:04 AM
I vote for "bug".
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-14 01:02 PM
In any case, I will report this to Graphisoft.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-14 02:03 PM
laszlonagy wrote:For my work, not having the line is sometimes desired, so I would not call it a bug. It could be a user setting if the Wall Settings > Floor Plan and Section > OutLines > Wall End Lines controlled the appearance of this line.
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-18 10:26 AM
you can also use the Wall End Tool to create a line between the walls. You should set the Overhang to 1.
I hope it helps.
Üdv,
Kati
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-18 10:48 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-20 09:26 AM
It happened to me also.
Another work around is to put the two walls into different layers with different number of layer or offset the reference line.
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-20 10:22 AM
Regards,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-20 11:21 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-12-21 12:02 AM
But the annoying thing is you have to save all your layer combination separately if you want your two walls to show line between them
