‎2007-07-19 12:51 AM
‎2007-07-19 09:13 AM
‎2007-07-23 02:42 PM
Don wrote:It depends. If Graphisoft comes out with a new release every year from now on (there was one year between 10 and 11), then it will only be version 13 (Unlucky number for PPC users?
I suppose this is common knowledge, but according to a GS press release Power PC will no longer be supported beyond 2009 (or I believe version 12).
Don Lee
‎2007-07-23 03:21 PM
‎2007-07-28 09:12 PM
TomWaltz wrote:I think that is indeed the reason: there are not two but three versions: Windows, PPC and Mactel... And with three different compilers (Visual Studio, CodeWarrior, XCode), I understand putting only effort in the newer systems. Too bad.
I think part of the problem is that GS is developing separate PPC and Intel versions. They are not using the Apple Universal Binary, that would be able to run on both PPC and Intel machines. I'm assuming this has to do with the amount of legacy code to be converted into the more modern programming system.
‎2007-08-16 04:18 PM
‎2007-08-16 05:21 PM
Mishi wrote:Would others please comment on this while my horror subsides?
So I can just say everyone that if you consider buying a new Mac i would just invest upgrading memory, fast harddrive and videocard in the old G5 systems. AC runs much better on them. I can prooove it.
‎2007-08-16 06:07 PM
Dwight wrote:I've found the Intel machines to cut about 10% off almost every process compared to the G5's running Archicad.Mishi wrote:Would others please comment on this while my horror subsides?
‎2007-08-17 07:23 AM
‎2007-08-20 08:56 PM
Mishi wrote:Oh.. i know this will sound like a no brainer but,.... How/where will I notice the benefit of more SDRAM vs. a faster Video card?
So I can just say everyone that if you consider buying a new Mac i would just invest upgrading memory, fast harddrive and videocard in the old G5 systems. AC runs much better on them. ...
