hi Cole_Construction,
first i would recommend the way, djordje described: more fun (with the bottles) and less brain usage necessary 😉
another way (in my opinion the best) is to use plt files. I dont know, if the printer you mentioned, is able to plot plt files, but most profecional plotters are.
the plot files are created with plotmaker and then only be sent to the plotter (no driver program or plotmaker or cad program is necessary). to send it to the plotter you can use command line or (easier) plotflow or another simple tool like this.
the advantage of plot files is their small size and the full scale print out.
But if you want to use pdf, you can also get a full scale print out:
- make sure, that the size of paper is same size or bigger than the size used in the pdf
- in printing settings you can see the scale: if it is not 100%, but near, change the setting "fit to papersize" to "no scaling" (or how it is called...)
best regards, gerd
