No more automatic grouping ?
CIA20
I noticed with the new Archicad28, the walls that are build with magic wand  (or in chain) are not anymore grouping automaticaly, why is this ?
I find it annoying, because usually I work on these walls as a bloc..
At least this what I was doing before. I can't figure out yet the advantage of this change..only the disadvantage and slowing the process.
Same is for the lines..
Does anyone finds it annoying too ?
Operating system used:
Archicad28 FR
Windows 11
Botonis
Mentor
Is there any chance that the "autogroup" setting is disabled....?
Just enable it.
Botonis
Mentor
Just enable it.
Indeed !!
The automtic grouping was disabled, I have never knew there was this option in other versions was by default 🙂 !
Anyways, thanks, I have enabled it and now it works again 🙂
So many years of Archicad and still so many things to discover !
Setup info provided by author
