2016-07-13 12:30 PM
2016-07-13 02:59 PM
2016-07-13 03:09 PM
2016-07-13 03:22 PM
2016-07-13 03:25 PM
arqrivas wrote:
If this is the problem you are having, the one shown in the video
http://screencast-o-matic.com/watch/cDiIIfiaIi
Then this problem happen when you have two lines on top of the other. See how was working at the begening and when I add another line right on top it did not work correctly. To fix this either clean manually the lines you are trying to offset, or use the line consolidation tool to clean all lines in your view to avoid this problem again.
2016-07-13 03:42 PM
