ā2022-05-13 08:20 PM
Is there a darn good reason out there to explain that when i create a new object, we still do not have a built in ability to rotate the object in any direction? Seriously - I really want to know why after a 1000 years we still can not rotate custom objects in any direction. When I bring in a revit object into Archicad it comes in with the ability to rotate in all directions - what's up with that???.
Yes I know we can add GDL to make this happen....
just saying ....
ā2022-05-13 11:23 PM - edited ā2022-05-13 11:25 PM
3 parameters and 3 lines of code
Parameters all angles
Xr
Yr
Zr
3d script
Rotx Xr
Roty Yr
Rotx Zr
Change 2d script to a projection. And this is the likely reason it's not a default. 2d scripts are much harder to get to match the 3d rotation with out projection. Which ultimately can make things slow, although that's almost a thing of the past with today's hardware.
I'm guessing the import function for Revit does just this
ā2022-05-16 11:08 PM
Yes i know I can add code to my custom GDL objects, but i have about thirty objects and it really just pisses me off that Graphisoft has not been proactive for the last 1000 years and made this happen automatically.
ā2022-06-08 03:54 AM - edited ā2022-06-09 05:32 AM
I totally agree because this one command makes Archicad looks ridiculously stupid to a new user who has been using other 3D softwares. This should be automatically coded in.
