Offset Stair Beam From Treads
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2020-05-12
07:44 PM
‎2023-05-25
04:38 PM
Rubia Torres
‎2020-05-12
07:44 PM
Any thoughts?
Thanks,
Chris
16" MacBook Pro M1 Max
Mac OS 12.2.1
ArchiCAD 25 Build 6005
Mac OS 12.2.1
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-05-13 04:10 AM
‎2020-05-13
04:10 AM
Make sure you have the flight set to use the profile origin as the anchor point.
Then adjust you complex profile so the origin is above the actual profile by the distance you want.
If that doesn't work then I am not sure there is any other adjustment.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-05-13 11:25 PM
‎2020-05-13
11:25 PM
Thanks for the response Barry. I actually got that to work, but it presents a whole new set of problems. Ha!
Mac OS 12.2.1
Mac OS 12.2.1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-05-17 02:03 AM
‎2020-05-17
02:03 AM
Yes, those Secondary Supports do not adjust, because they assume the top of the Beam is not offset.
Right now you would probably have to delve into and modify the "Flight Beam 23" GDL Object to handle this issue.
I will forward this to GRAPHISOFT, call their attention to this. Its solution may be as little as modifying that GDL object for this to work correctly. Of course, the Beam offset would have to be a parameter of "Flight Beam 23" and not a workaround achieved by Complex Profiles.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-06-03 09:54 AM
‎2020-06-03
09:54 AM
Hi All,
I hope everything is going well for you!
I am happy to say we took notice of this wish and I have added it into our WishList database (please refer to it as Wish #12747). Hopefully, our Product Management team will adopt this one in the future.
Thank you all once more, and I wish you a great day!
Best regards,
Minh
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
