Offsetting Walls
I found lots of information about offsetting polylines, but can't seem to find a way to offset a wall. I need to offset a curved wall and "drag a copy" wont make the curves concentric so I need an offset function...anybody help with this one?
9 REPLIES 9
One way is to copy the wall, paste the copy, select either wall
and when the pet pallet comes up select the offset method and
enter the radius for the offset wall.
Peter Devlin
select the wall and activate wall tool
also activate offset command
press spacebar and click on the wall and drag
sorry, donot select the object. activate the wall tool and offest comand
press spacebar and click on wall and drag.
That's pretty much it. Offset the wall the same as offsetting a polyline - Magic Wand.
I cant find offset at all on my computer. Which is strange because others here have it. I heardyou press 'o' to also enable offset but that does nothing either. Is it on the recent patch?
Nats
Aaron Bourgoin
Th Offset Tool can be made visible by activating the "Control Box' pallette from The "Window" Menu.
Once you can see it on your screen, ask someone in the office to show you how it works.
Cheers!
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.27 Mac
MacOS Tahoe 26.2
TomWaltz
Nats
It's probably a difference in Workspace. If you show the Control Palette, then O should work. If not, you might need to add it to your keyboard shortcuts.
Tom Waltz
Nats
Go to Windows / Pallettes / Control Box, it should look like the image below
Cheers!
Thanks I have it now. I've even finally figured out how to offset splines using polylines and the magic wand! Thats been bugging me for months.
Nats
