One Object different material in View Map
Situation- Would like columns to have concrete material, but when working with Eptar Reinforcement plugin(In View Map) can the material be Transparent Glass so that the rebar can be seen
or there's another workflow ?
Thanks in advance
3 Replies 3
rocorona
Materials are not stored as part of the Views.
For your purpose, I would group the columns so they can be selected all at once to (manually) set the material as needed.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
Not sure how the Reptar Plugin works, but you can set a Layer Combination to show the columns as transparent.
Another workaround could be to have two sets of columns on different layers (with Layer Intersection Priority set to 0 when off, so as not to affect other elements) with one set concrete, and one set glass.
vistasp
Mentor
Narin, would it suit your purpose to make the column layer wireframe for that view?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
