Only my windows shows in 3d
Suddenly I can't see the model in 3d. It is OpenGL engine I'm using.
The only things that shows are the windows. I thought it had something to do with layers, but I've choosed Drafting, and that is what is usually on.
But the problem is still there.
I didn't make any change before this occured I belive.
Do someone understand what I should do about it?
5 REPLIES 5
This has happened to me before when going to 3d and there was a corrupt 3d object.
Did you get an error report?
Link
Yep sounds like a corruption or a solid element operation gone wrong (ie. using the wall as an operator and a target in the same operation).
Link.
You are probably right about the corrupted object. I've been trying to edit an object I made myself, without any success. And now one of the parts the object contains (a wheel) is still in my project. I'm not able to get rid of it.
It's impossible to select. Do someone have an idea upon how to get rid of the object, please ?
I managed to get rid of the corrupted object, and now the 3d-view works as expected. So thank you very much for your advice.
You welcome.
Glad you got rid of the wheel that was in the ditch:-)
"Wheel in the ditch" is a US expression I believe.
But, as soon as I say that, someone is sure to prove me wrong:-))
