We value your input! Please participate in Archicad 28 Home Screen and Tooltips/Quick Tutorials survey
2022-02-16 03:25 PM
When opening the section views from the plan or details from the section, it will open with current view settings of the floor plan. Is there a way to change that setting to actually open with the correct setting those sections already have implemented? Or is it best practice to always open them from the View Map?
Solved! Go to Solution.
2022-02-18 04:32 PM
Yes, I think that feature is pretty cool. The more I'm using Archicad, the better I'm starting to like and understand the program compared to Revit. I think I find it a bit easier to work with so far. I really like the ability to temporarily change the settings without it being permanent and not needing to remember to change it back once you're done with it.
