Opening lines doors not showing
I have a problem with the opening lines from my doors not showing. Its killing me because i cant find the solution.
At door selection settings every setting is oke. Opening angle, solid line, line color etc. etc. But its not projected in my drawings.
Also i checked 2d presentation and all the settings are correct. It even show a opening line at the preview and positioning box (right top corner).
When i start a new template, the settings work correctly. Just not in the file im working on atm.
Please help!
Best regards
David Maudlin
Seren:
One thing to check is Door Settings > Floor Plan and Section > Floor Plan Display > Floor Plan Display > Symbolic. It looks like the door is not set to Symbolic, so the 3D Model of the door is being cut through in plan (using the Floor Plan Cut Plane).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Thank you master David. Your solution worked!
I'll add a signature.
