2017-04-04
		05:46 PM
		2023-05-24
		08:32 AM
			Rubia Torres
2017-04-05 02:44 AM
2017-04-05 03:02 AM
2017-04-05 11:59 AM
2017-04-05 01:26 PM
2017-04-05 02:51 PM
2017-04-06 02:33 AM
Karl wrote:I will have to experiment some more.
Defining the opening reference line in the complex profile fixed this.
I am using 'symbolic' for openings, and that seems to be working correctly for me.
2017-04-06 01:06 PM
2017-04-07 02:40 AM
Karl wrote:No it makes no difference which side of the wall I place the window on.
Would it behave differently if you snapped the opening reference line to the exterior face of wall and entered the recess dimension (instead of placing the reference line at the desired recess location)?
Karl wrote:This is just because one window is symbolic and the other is projected.
Also, I notice one window has the interior skin turned in and the other doesn't. I don't know if that makes any difference, or if there are different settings between the two windows.
2017-04-07 01:39 PM
Barry wrote:That's why it is working for me - I have the opening reference line positioned at the exterior face of wall. However, this face of wall is inset from the face of wall above the opening, so the reference line is useful in that it allows me to select the relevant wall face. I expect that if I moved it off a wall face, would behave as you note. But I'm trying to get this project done, so I'm not moving it!
I can manually set the reveal depth but the problem is the plan will move from the edge of the wall and in 3D it will move from where the opening reference line is.
So it only works if the opening ref line is on the face of the wall so 2D and 3D match.
