PM9 not displaying CE fonts correctly!
MarinRacic
What's up with PM9? It doesn't show any of the Central European characters when I enter them into Book Info fields and then use 'em through Auto Text option in the layout.
I've tried this both on OS X and Windows - same problem, just a little bit different behaviour! On a Mac, characters aren's displayed at all in the Book Info entries while on the Windows platform CE characters get substituted with some western encoding characters.
A bug? PM 3.1 works fine with this...
BTW, ALL the CE characters are displayed ok when entered directly in the layout (not using Book Info).
MBPro Retina 2.7i7/16GB/SSD
AC ...20/21
www.3Dart.hr
1 REPLY 1
Gorazd
Hi
The problem with Autotext and CE fonts can be solved on PC with registry editor. Got to regedit (start/run/regedit) and find HKEY_CURRENT_USER/SOFTWARE/... to find Plotmaker 3.1. In a field FONT SCRIPT CODE write 238 instead of 0. Restart Plotmaker and CE fonts will work. The same goes for Archicad 8.1 or 9 for using CE characters in layer names, stories,...
Gorazd Rajh
From AC 6.5 onward, Ryzen 9 5900HS, 48 GB RAM, RTX 3080, Win 11
