We value your input!
Pan / Zoom Previous Shortcuts
Eduardo Bell
Anybody knows if it is still possible to create keyboard shortcuts for the Pan and Zoom previous display modes? (Archicad 9)
I can't seem to find them other than as icons at the bottom of the working windows.
USA v4.55 to v28-b3001 OS Sonoma v 14.6.1
MacBookPro 8-Core Intel i9 16GB ram
AMD Radeon Pro 5500M 4GB vram
Perpetual License Subscriber
4 REPLIES 4
this should answer your question.
Eduardo Bell
Patrick I appreciate your reply, however I can't see how it helps because I can't see the zoom previous or the pan options in the jpg you sent.
TomWaltz
I believe the idea is that he was showing you the menu to use to create your own shortcuts, not necessarily the exact steps of how to do so.
The Archicad 9 User Manual is quite descriptive of the procedure.
Tom Waltz
TomWaltz
DOH!!! But of course, those commands are not so easily found in the customization menu, even when using Alpha or Theme sort....
Well that's a pain!
Tom Waltz
