Parapets in plan
KeesW
Is this a wishlist item?
I have a parapet wall on a roof storey, directly over a same width and constructed wall underneath, on a lower storey. When I draw a section, both parapet and wall under join perfectly and are hatched alike. Just what I want. But when I go to the roof plan, my parapet walls are hatched in plan -which I don't want. Drafting conventions are that items which are cut are hatched, items which are viewed from the top, are not hatched. Full height walls are traditionally shown hatched, but low walls are shown plain. There are work arounds - like putting a blank fill over the wall - but is there an easy, automatic way?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
8 REPLIES 8
Djordje
It is a wishlist item and no, there is no easy automatic way ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
presumably there's some sort of coping to weatherproof the top of the wall
so, draw the wall on the storey below to the u/s of the coping, then draw the coping with the slab tool (or mesh if it has a raking top)
bill
Djordje
Exactly what I do ... with the added benefit of being able to show one storey up or down. You can also do the coping beam using the beam tool, that solves the problem somewhat.
Djordje
HP Omen
TomWaltz
You could probably do this using the display option to turn off fills inside walls on the roof plan.
Tom Waltz
__archiben
because we often use a slightly different wall construction/composite for the parapet walls, we find that using a separate layer for copings works well:
the parapet walls are drawn on the usual external walls layer to the correct height, hatching and all. then we use a low thick wall for the coping with a solid white fill over the top of the parapets.
this means that GA plans, containing all the building information, display correctly on output, but toggling the coping layer and GA notes layer off, and turning on parapet notes, we have a drawing set for the parapet walls.
HTH
~/archiben
b e n f r o s t
KeesW
Thank you for your replies. The issue also applies to internal low walls without copings - such as low walls around stairs. It is more concerned with principles of presentation in draftmanship.
I will put a thin coping over the parapet, and associate text notes with it.
David Collins
While we're contemplating the long standing parapet wish list item, it would be great to have this coping workaround incorporated directly into the wall tool. You could specify if the wall terminated in the current plan view and go on to give dimensions, type, materials for the coping, which would show properly in section and elevation and clean up nicely in plan without displaying a fill. Maybe there's an option to show the wall below in dashed lines?
Mind you, not another wall accessory add-on type thing, please: A basic enhancement of the wall tool.
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
aahatimo
how about as an enhancement to the wall end tool?
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
