Patch Tool
I just discovered what the patch tool does! Haven't had a chance to apply it yet. I am curious as to what others are finding it most usefull for. Do you guys use it regularly? Thanks
Petros Ioannou
Sometimes someone can use it along with the detail tool on construction documents.
Lets say that you created a section of a window (scale 1:50), then a detail drawing from that section(1:10).After adding the appropriate details you can create a patch from this detail-drawing (using also hotspots) and place it on all sections(1:50) where this type of detail appears.You can hide or not fills and text so that things are not over-drawn on this scale. Same with railings, joint covers etc.
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
Erika Epstein
cleaning up wall intersections
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
