2011-08-17
		04:08 PM
		2023-05-24
		01:06 PM
			Rubia Torres
2011-08-17 04:35 PM
2011-08-17 09:38 PM
2011-08-18 06:09 AM
Keith wrote:I assume your using the Patch tool (Document> Document extras).
2. There is no way of updating a patch, other than deleting and starting again
Keith wrote:Place "hotspots" at the points you want. Then create the patch. The hotspots will become pick points.
3. The pick points of the patch are only its corners - so you can't accurately position a patch unless a patch corner coincides with a junction on the drawing. This is hard to achieve because the patch is best done with a margin to ensure that lines near the edge are included and visible.
2011-08-18 07:04 AM
Keith wrote:No because the patch just becomes an object and objects don't have layers.
The problems with patches seem to be:
1. Layering is not honoured, lines on layers included in the patch remain visible when the layer is turned off.
Keith wrote:If you can select exactly the same marquee area (ie place hotspots before creating the patch then you can simply save with the original name. This will replace the original patch object and all placed instances will update.
Keith wrote:The patch has an parameter setting to turn on or of the opaque background - does this help?
I've been experimenting with using modules instead of patches. Since I noticed that the patch automatically adds an 'Airspace' fill as a mask, I've included this in the module. This approach overcomes the above problems, and has the additional advantage that the modules are more readily available to different drawings. However, for some reason the 'Airspace' fill no longer masks the underlying junction. Or, at least, not in every case. This is irrespective of the display order set for the 'patch' module or for the underlying module.
2011-08-18 08:22 AM
2011-08-18 06:32 PM
2011-12-06 12:45 PM
2011-12-06 01:41 PM
