2017-05-13 09:54 PM - last edited on 2023-05-23 04:15 PM by Rubia Torres
2017-05-14 02:41 AM
2017-05-14 02:43 AM
2017-05-14 04:46 AM
2017-05-18 09:55 PM
famadorian wrote:This would require constraints and there are only a few constraints currently in ARCHICAD. For example, Base and Top Link for Walls, Columns and Zones (and Stairs in AC21) so you can constrain their base and top to Story levels.
Is it possible to set an object a permanent distance from another object?
For example,
* the door is permanently 520mm from the corner.
* the window is permanently 1000mm from the corner
* the light switch is permanently 200mm from the door
2017-05-18 11:59 PM
