SOLVED!
Placing window / door on elevation & 3D views
Johann_P
It seems I can only place windows and doors successfully on plan views.
I've been able to place them on 3D views too, but the door / window's associated storey seems random.
1) In 3D, can I define the associated storey for the door / window to be linked too?
2) Can I place door / windows in elevation view?
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
1 ACCEPTED SOLUTION
Solution
What ever storey you are in in plan view when you switch to 3D, is the storey the window will be placed in in 3D.
However you can drag the window as you wish.
It will remain linked to the storey it was placed in until you re-link it.
No.
1 REPLY 1
Solution
No.
