Ted Taylor
Plan View of low non cut walls
With top of walls lower than Floor Plan Cutting Plane. Is it possible to have walls show correctly in plan window? i.e Walls show break in plan view where top of walls height change occurs? Projected does not do it, that I can figure.
Sorry about PDF, but too many pixels wide to show directly.
Ted Taylor
Atlanta, GA , USA
iMac (Retina 5K, 27", Late 2015)
3.3 GHz Intel Core i5 32GB
AMD Radeon R9 M395 2GB
OS10.14.2,
Latest Archicad 22
3 Replies 3
Aussie John
Ted do you have the cut plane above the level of the low walls?
Cheers John
[/size]
Ted Taylor
I do. Cut plane is at 4'-0" and top of tallest wall is 3'-0"
Ted Taylor
Atlanta, GA , USA
OS10.14.2,
Latest Archicad 22
No. Floor Plan Projected is still not a true 3D view. Such walls act like one-skin, empty, regular walls, including corner cleanup. A wish.
James Murray
