2007-03-04 07:44 PM - last edited on 2023-05-25 06:32 PM by Rubia Torres
2007-03-04 10:40 PM
2007-06-06 12:40 PM
2007-06-06 03:39 PM
justdhruv wrote:The finish is defined by the ArchiCAD "Material" which just defines the surface appearance. This will all match by default but can be varied edge by edge in the profile.
Actually, what i want to do is illustrated in the attachment. There are two purposes for doing so.
1. i want to have a single colour/finish on all surfaces, which in this case will be plaser or painted plaster
2. The whole idea or one of the main ideas of going BIM is that one is able to take quantity take off from the model. So i want to model in such a way that my model can give surface area(and perhaps the volume) of the plaster as well.There is no automatic wrapping for beams (or anything) in section the way columns and wall interact in plan. In fact, fill clean up in section is generally not good (big wish list item).
I explored the complex profile manager, but i could not figure out if it one is allowed to have skins/veneers around the complex profile.
Can slabs and beams also have a wrapping option just like column have for inserting in walls.
2007-06-06 10:44 PM
2007-06-07 01:43 AM
2007-06-07 07:48 AM
