Plotmaker - Why does it default to Shrink Layout to page
In plotmaker, Nearly evertime i press plot or print i have to go into the plot/print settings and make sure "Shrink each Layout to page" is not OFF. This is very annoying not to mention a problem as sometimes people forget to select this option and end up with drawings slightley out of scale!!
By default it should plot/print to 100%
Am i missing something here?, does anyone else have this problem?
4 REPLIES 4
aahatimo
mark,
this was a problem w/ ac8.0 us versions. it works fine for me 8.1. it was a major pain before gs fixed it.
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
ok, thanks tim,
still not on 8.1 so will look forward to when we it is finally available in Australia.
Mark.
aahatimo
i hope you guys get 8.1 soon! till then you can print/plot in pm3.0 w/ publisher, once you get settings correct there, they "stick".
tim hanagan
AC10 - my default print scale is "Fit to page", is there a way of changing this to 100%? And why is 100% a custom scale?
