2004-02-09
06:28 PM
2023-05-25
05:17 PM
Rubia Torres
2004-02-09 06:37 PM
2004-02-09 07:08 PM
2004-02-09 11:04 PM
2004-02-09 11:07 PM
2004-02-10 12:30 PM
Petros wrote:Fills won't explode in ArchiCAD (though you can copy/paste to and from PM) so slabs would work better for this.
In case the survey drawing is not too large you can use the fill tool combined with the magic wand to trace areas between elevation lines. This trace of an area can be extended (select the fill and add areas using the magic wand). Then explode the fill and proceed working with the lines. Success is not guaranteed since the tracing may lead to unaxeptable results.
2004-02-10 01:23 PM
2004-02-10 02:42 PM
2004-02-10 03:28 PM
tsturm wrote:One thing that occurs to me is that is appears you are not using layers to separate the contours from other site features. Did your surveyor not give you his full DWG? It seems this would make your life much easier.
Thank you all for the suggestions. They all seem like they could work, but it would seem they would all take longer to get the same results with the complexity of our site.
