Problems that don't seem to have been fixed or addressed (based on a first reading of that list):-
- ArchiCAD incorrectly exporting extra unwanted geometry (related to the last couple of edits or modifications done before export) from the 3D window when exporting a 3D model to some 3D format to be used in some other program (like rendering or even IFC).
- ArchiCAD randomly completely freezing or crashing, necessitating a complete system restart to flush the ArchiCAD.exe from the system processes before another session of ArchiCAD can be started. Typically related to Cinerender crashing or freezing during a render or start of a render or sometimes just opening the Render dialog box and the preview starts to refresh - but not always only because of this.
-ArchiCAD not automatically updating materials or surfaces in the 3D window in the case of a change to the materials settings, until you force an update by changing the surface of an object. Not as big a problem but nonetheless annoying and infuriating especially when you forget and are doing an export.
-Whatever problem it was which was preventing the Nextlimit people from updating the Maxwell render bridge, forcing people to have to go back to AC17 to use Maxwell render.
Obviously most of these are not as being problems or debilitating and you can mostly work around them, but regardless, it's still perplexing that it's almost a year passed since this version was released and these problems haven't been addressed by any Hotfix version, and we're probably a couple of months away from ArchiCAD 19 release.
Does this mean that if a hotfix (other than this one, and in the coming months) doesn't fix these issues soon that we should expect them to re-appear in AC19, or is AC19 our best hope of getting some of these issues addressed.
Something tells me that AC19 will have it's own unique set of issues and problems prior to the first hotfix before compounding it with unaddressed issues from AC18.
