‎2007-12-10 08:25 PM
‎2007-12-10 11:01 PM
Chris wrote:No. You can simply select the view in question on the layout, right (ctrl) click on it and go to "Drawing Selection settings" and change the scale there. The whole view will re-scale, if you go from 1/8" to 1/4" it will double (linear) in size.
edit - as far as changing scales, you would have to go back and change the source view settings to the new scale you want
‎2007-12-12 08:32 AM
Seraphim wrote:It's here:
It figures.....according to the help menu the print dialog menu seems to be specific to MacOS. Anybody know what it would be called for windows? (The help even mentions the ArchiCAD pane. Wish I could find it in windows.)
‎2007-12-12 08:39 PM
Thomas wrote:You can, but I would recommend changing the original view scale. Only change the drawing scale on the layout as a last resort.Chris wrote:No. You can simply select the view in question on the layout, right (ctrl) click on it and go to "Drawing Selection settings" and change the scale there. The whole view will re-scale, if you go from 1/8" to 1/4" it will double (linear) in size.
‎2007-12-12 09:30 PM
s2art wrote:I agree and raise.
‎2007-12-12 09:34 PM
‎2007-12-12 10:57 PM
James wrote:
I agree and raise.
‎2007-12-13 01:33 AM
Thomas wrote:It's good to direct those first steps in the right direction though, don't you think?James wrote:
I agree and raise.OK. Punch it in, guys. I thought at this level of experience, I could give him the simple way. There are so many options and ways to do things in this program, and of course consistency and manageability are primary in a project where several people are involved. But ease of use - and of learning - are also worth considering, especially when you take your first steps.
‎2007-12-13 09:36 AM
Seraphim wrote:
The various ideas and contradictions are providing WAY more real life application than the help menu ever does!
‎2007-12-14 12:34 PM
Thomas wrote:This should be done only if you have 2,5 seconds to print.Chris wrote:No. You can simply select the view in question on the layout, right (ctrl) click on it and go to "Drawing Selection settings" and change the scale there. The whole view will re-scale, if you go from 1/8" to 1/4" it will double (linear) in size.
As Rick put it: Time to pull out the manual. You've got all the docs with the default instalation. It's readily available in the Help menu!
‎2007-12-14 12:36 PM
Thomas wrote:Sorry, have to disagree. You should NEVER point out a way that is fundamentally wrong. The fact that the option exists is not the reason to use it. New users have to be taught correct ways from the start. The quick and dirty methods are for crunch moments, and more often than not, they will come back to haunt you ...James wrote:
