Problem Changing From Archicad 10 to 11
I'm having a problem changing over from using Archicad 10 to archicad 11. If i open a drawing that has been created in AC10 in AC11, i first get a window called library manager, and if i go out of library manager without changing anything, all my library parts dont show up in the drawing.
Im sure this has something to do with the fact that the library parts iv used in the drawing and others were done in AC10, but how do i get my drawings to show up properly in AC11?
Any help would be much appreciated.
Thanks alot.
1 REPLY 1
You have to download the "ArchiCAD Subset Library 10.icf" file and place it in you ArchiCAD Library 11 folder. If you click on help in ArchiCAD 11 and then on ArchiCAD 11 Goodies you should find a link to download the library subset file.
