2007-12-11 06:44 AM
2007-12-11 06:49 AM
2007-12-11 06:58 AM
2007-12-11 11:05 AM
2007-12-11 02:21 PM
2007-12-11 05:38 PM
2007-12-12 12:25 PM
2007-12-12 12:28 PM
2007-12-12 12:30 PM
2007-12-12 01:49 PM
EDDY wrote:When you use File\Save as... in the appearing Dialog, select PLN as file type, there is an Options button. If you click it, you have the choice to set Compression ON. This wil ldramatically reduce file size. If you already have Compression ON and your file size is still 218 MB, then it must be a huge file, which must have huge amounts of data and elements in it.
Thanks...,
I Say Thanks very much for opinion and all solution my problem.
I try delete one or more line section problem and create new one or more line section and success rebuilt and clear.. no problem, but I'm reinstall system X64 and reinstall AC11 because my system slow begin.
My File project is working AC11 built 1114 and large file 218 MB, is normal and real?..
