Problem: Walls and elements are invisible in elevation
Hi everyone,
I'm trying to set up elevations for an existing project. When I open the elevation I can see the contour/cut of windows and other objects that should be invisbible far back in the elevation. I have no idea what can cause this, so I hope you can help instead.
EDIT: I have found out that the issue is related to display order of elements. When I move the exterior wall further up in the dsplay order, the windows are hidden. But this ruins the look of the facade, and hides the contour lines of the windows that are supposed to be shown in the exterior walls. And when I send the interior walls with the windows further back, nothing happens. So the problem still persists.
Screenshots explaining the problems:
Elevation problems http://imgur.com/EXyaiK5
3D of same area http://i.imgur.com/Weh8P7K.jpg
0 Replies 0
