Problem connecting walls to ceiling
I'm new at archicad and I have a problem. Sometimes my walls sems to be visible through the ceiling? I can't find what it is and why.
Could anyone explain for me why it does that?
Cheers
Roger
2 REPLIES 2
David Maudlin
Roger:
This is a result of the Intersection Priority strengths of the Building Materials used for the Roof and Wall. You can either make the Roof stronger than the Wall (when using the Connect command), or use Solid Element Operation (SEO) rather than Connect.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
David, thx alot!
The use of SOE did the job.
I will add a signature, missed that.
//Roger
