Problem in 16 3D Window
I recently began a new project in ArchiCAD 16. When I am in the 3D window I often get a white "plane" that interferes with the tops or bottoms of objects I am trying to see. How do I turn this "plane" off? Never saw anything like it in 14.
Thanks for your help.
just turn it off from the Menu: View / Editing Plane Display.
or try this...
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Thanks for the second option NandoMogollon. I tried the transparency and it worked fine for that window but when opening another 3D window the transparency resets itself and I have to repeat the process. I wonder what could be causing this to happen?
rocorona
That is not a good solution. I suggest to keep the transparency ON, and set OFF the visibility (View Menu).
In the Work Environment > View Option (or similar) you ave another checkbox to choose if the editing plane will be always visible, or only during the editing work.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
