Mr Architect
Problem in creating Staircase
Hello Everyone,
I would appreciate any assistance. Since I'm having trouble creating a staircase, I've also attached the snaps.
Problem #1: How can we create a Double landing staircase at levels 2nd to 3rd?
Problem #2: We are making a staircase at level (3rd to 7th). How can we create a multistory stair from level 3rd to 7th and connect both?
Problem #3: We are having a railing connection issue, it's detached from the landing at every floor. How can we solve this issue?
I'll be appreciative!
10 Replies 10
Lingwisyer
Guru
Please do not duplicate your posts. There is no need. If you are doing it because of Threading, that's just another reason to disable that functionality...
Regarding the concrete, check your Surfaces Vectorial Fill. The Pen used can also be overridden there if need be, else check your walls settings under Outline Pens, though this will change more than just the pen for the hatch...
Ling.
