2024-02-07
01:35 PM
- last edited on
2024-02-13
07:11 PM
by
Hello. I was wondering if it's possible in ARCHICAD to create bottom hung doors. Doors in ARCHICAD library only have side hung or double acting opening types. I need to add bottom hung function in an easy way to show them in Door Schedule.
Here's an example of how I want the doors to be drawn in the schedule:
2024-02-07
03:11 PM
- last edited on
2024-02-13
07:24 PM
by
Hi @Kikoria
Maybe you could use a Double Window with a Botton Hung main sash instead. To be listed as a door just change its classification.
It is not perfect, but I hope it works for you.
Regards. -
2024-02-08 12:40 PM
Thanks for your reply! Yes, that's how I do it currently and that's the best alternate way. But the thing is, technically it's a door and in the floor plan it has a different representation. That's why I wanted it to be done by the Door Tool.
2024-02-08 12:55 PM
Hi @Kikoria,
only want to know when the bottom hung door can be requested?
2024-02-09 02:11 AM
I am curious about this door too.
So basically it is like a draw bridge?
You will actually wall on the door?
I assume it will need a rope and pulley system to open and close it?
Do you have any images?
I have heard of bottom hung windows and bottom hung bi-fold/sliding doors, but not a bottom hinged door.
2024-02-12 08:04 AM
Here it is:
2024-02-12 08:05 AM
Hey Barry. This is how they look like:
2024-02-12 08:24 AM
I see, thanks.
So it is not an opening for access, just ventilation.
Basically it is like a tilt & turn window.
So hinged doors also need a 'tilt & turn' option like the windows.
You might need to make a wish in the wishes forum for that.
There must be a lot of force on the mechanism locking it in place like that.
Especially with double or triple glazing.
2024-02-12 08:57 AM - last edited on 2024-02-12 09:09 AM by Barry Kelly
Exactly. It would be very nice if doors had tilt & turn option. Thanks for your advice!
Please see wish here ...
https://community.graphisoft.com/t5/Wishes/Tilt-amp-Turn-Option-for-Doors/m-p/587732#M24429
2024-02-13 10:00 AM
Thanks Kikoria, wish you the best.
