Bottom Hung Doors
Kikoria
Hello. I was wondering if it's possible in ARCHICAD to create bottom hung doors. Doors in ARCHICAD library only have side hung or double acting opening types. I need to add bottom hung function in an easy way to show them in Door Schedule.
Here's an example of how I want the doors to be drawn in the schedule:
Kind regards,
Tamaz Kikoria
Architect
Technical Examination and Design Department
GEORGIAN WATER & POWER
10 REPLIES 10
Ricardo Lopez
Hi @Kikoria
Maybe you could use a Double Window with a Botton Hung main sash instead. To be listed as a door just change its classification.
It is not perfect, but I hope it works for you.
Regards. -
ā€ƒ
M. Arch. Ricardo López
Thanks for your reply! Yes, that's how I do it currently and that's the best alternate way. But the thing is, technically it's a door and in the floor plan it has a different representation. That's why I wanted it to be done by the Door Tool.
Kind regards,
Tamaz Kikoria
Architect
Hi @Kikoria,
only want to know when the bottom hung door can be requested?
AC 28 INT 5200/WIN 11
@Kikoria
I am curious about this door too.
So basically it is like a draw bridge?
You will actually wall on the door?
I assume it will need a rope and pulley system to open and close it?
Do you have any images?
I have heard of bottom hung windows and bottom hung bi-fold/sliding doors, but not a bottom hinged door.
Here it is:
Kind regards,
Tamaz Kikoria
Architect
Hey Barry. This is how they look like:
Kind regards,
Tamaz Kikoria
Architect
I see, thanks.
So it is not an opening for access, just ventilation.
Basically it is like a tilt & turn window.
So hinged doors also need a 'tilt & turn' option like the windows.
You might need to make a wish in the wishes forum for that.
There must be a lot of force on the mechanism locking it in place like that.
Especially with double or triple glazing.
Exactly. It would be very nice if doors had tilt & turn option. Thanks for your advice!
Please see wish here ...
https://community.graphisoft.com/t5/Wishes/Tilt-amp-Turn-Option-for-Doors/m-p/587732#M24429
Kind regards,
Tamaz Kikoria
Architect
Thanks Kikoria, wish you the best.
