I must to draw these clerestory (hope the name is correct), in two different projects. Can someone explain me with pictures how to proceed?
I have only Archicad 11.
thanks
In ArchiCAD 11 you could sort of make the shape with a slanted profiled beam (custom profiles). I say sort of, because the actual profile cut of such a roof isn't the same shape extruded.
It's not an easy thing to model.
This approach would require quite a bit of solid element operators to cut the 'roof' to the shape needed.
