2013-11-14 12:26 PM
2013-11-14 12:40 PM
2013-11-14 12:43 PM
Erwin wrote:Thanks for answering!
If it is just for presentation work (not IFC model export, exchanging BIM info), you could make the concrete surface material 100% transparant and it won't show up in renders.
2013-11-15 11:17 AM
2013-11-15 12:05 PM
Peter wrote:
I had the same problem. I modeled the construction separate from the finish. This way I could easily export an ifc without the construction. Not the most efficient way, but until there is no other solution within ArchiCAD...
Luckily my project wasn't that complicated.
