Problem with Composite structures
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2013-11-14 12:26 PM
2013-11-14
12:26 PM
I am new to ArchiCAD and could use some help. If I have a Composite structure consisting of, let's say 100 mm insulation + 200 mm concrete + 100 mm insulation, is there a way I can create a 3D-view for export that shows only the insulation skins and not the concrete?
I have accomplised the reverse, by setting the insulation skins to "Finish" or "Other", and the concrete to "Core", and then chosen "Without finishes" or "Core only" in the view.
Is there some other way to accomplish this, with say filtering the view by material or something similar?
Thanks in advance!
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-11-14 12:40 PM
2013-11-14
12:40 PM
If it is just for presentation work (not IFC model export, exchanging BIM info), you could make the concrete surface material 100% transparant and it won't show up in renders.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
www.leloup.nl
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-11-14 12:43 PM
2013-11-14
12:43 PM
Erwin wrote:Thanks for answering!
Unfortunately it IS for IFC/NWC model export!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-11-15 11:17 AM
2013-11-15
11:17 AM
I had the same problem. I modeled the construction separate from the finish. This way I could easily export an ifc without the construction. Not the most efficient way, but until there is no other solution within ArchiCAD...
Luckily my project wasn't that complicated.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-11-15 12:05 PM
2013-11-15
12:05 PM
